1994 Honda Accord radiator fan always on when ignition is t
150,000 MILES • 4 CYL • FWD • AUTOMATIC
QUACHDAVID
How come the radiator fan ( the one that is located next to the battery ) is still on after the engine is shut down. It kill my battery the next day. Please help, thanks in advance.
Oct 8, 2009 at 4:19 PM
HONDA TECH 1818
  • 536 POSTS
Check the radiator fan relay under the hood fuse box, inside the fuse box cover it should tell you which one is the radiator fan relay. Remove the radiator fan relay and take the power window relay (next to the radiator fan relay) and put it in the radiator fan relay slot and see if the radiator fan is on when the key is off.
Oct 8, 2009 at 4:51 PM
