1994 Honda Accord overdrive shift problem
1994 HONDA ACCORD
147,000 MILES • 4 CYL • 2WD • AUTOMATIC
GARY MCELWEE
I have a overdrive problem. The transmission shifts fine but when i get up to highway speed it is reluctant to shift into the top gear.It does eventually but if i keep at a steady speed [say 65 to 70mpg] it will downshift and shift up again.Ive had a similar problem like this many miles ago and i cured it buy changing the thermostat.i did so again but this time no luck.The fluid is full and clean and i dread the expense of transmission work.What do you think.
Jan 23, 2009 at 7:55 AM
KHLOW2008
  • 41,814 POSTS
Hi Gary,
You should check the fluid level and throttle pressure cable adjustment. The thermostat should have nothing to do with this.
Jan 29, 2009 at 8:42 AM
