1994 Honda Accord oil pan bolts
MANDERS
Engine Mechanical problem
1994 Honda Accord 4 cyl Manual 259,00 miles
i think that i have a oil leak. someone that looked at my car said that my oil pan was missing some bolts and the leak was from the oil pan about to fall off.
the person tightened the loose bolts that were still there but i think that the pan is shaken loose again.
i just need to know if i need a spacific type of bolt for and the pan and were they can be found.
Feb 18, 2009 at 3:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
They can be found at any local part store, or they may have to order them. You need to torque the bolts properly or they will just keep coming unthreaded. Also need to replace the gasket.. Give me engine size and I will post torque specs..
Thanks for using 2CarPros.com!
Feb 18, 2009 at 4:59 AM
MANDERS
ummmm... a 2.2L
i hope thats what you are talking about. i can't believe that i have kept this car running this long.
LOL! thanks for all your time.
-Amanda
Feb 18, 2009 at 6:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Tighten the nuts/bolts to 10 ft. lbs. (14 Nm). Use an alternating or crisscross pattern to tighten the nuts and bolts.
Feb 18, 2009 at 11:35 AM
