1994 Honda Accord noise
143,000 MILES • 4 CYL • FWD • AUTOMATIC
NUGGYHEAD
Only when going in reverse, there is a squeeling noise, which sounds like it is coming from the right rear wheel. There is none of this noise when going forward. What could be causing this?
Aug 9, 2009 at 4:23 AM
F4I_GUY
  • 3,302 POSTS
Check your brake lining material. You might be hitting the squeeler on the brake pad. This is to let you know that your brake material is low.
Aug 9, 2009 at 5:44 AM
