1994 Honda Accord My Accord Battery
IATM53
  • 1994 HONDA ACCORD
  • 4 CYL
  • 195,000 MILES
Hi my 94 Honda Accord LX will not start. When you turn the key you get nothing. But if you jump the car it starts and runs fine until you turn it off again. What is this?
Tuesday, October 12th, 2010 AT 12:55 AM
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, October 12th, 2010 AT 1:20 AM
IATM53
Yeah its totally dead. But it stars when you jump it, doesn't this mean all starter issues should be ok?
Tuesday, October 12th, 2010 AT 2:07 AM
Start at the starter motor it needs more than 10volts to function properly, also check the battery, alternator and connections
Tuesday, October 12th, 2010 AT 2:53 AM
