1994 Honda Accord lack of power
KN0222
  • 1994 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 126,700 MILES
Every time I shift from 1st gear to 2nd gear, it seem like the car have lack of power. Its like the car pull back when I shift to 2nd gear from 1st. I recently done a tune up and replace the fuel filter and oil change. Can anyone have any suggestion on this? Thank you.
Thursday, April 2nd, 2009 AT 11:11 AM
F4I_GUY
  • 3,302 POSTS
Ensure that there are no pending or trouble codes in the ECU.
Ensure that ignition timing is properly set and that fuel pressure is reading properly with full vacuum and no vacuum.
If that checks out, it may be a sensor that is out of range. It may be the ECT, MAP, etc.
Friday, April 3rd, 2009 AT 5:56 PM
