1994 Honda Accord I fixed my radiator hose, and my thermost
1994 HONDA ACCORD
190,000 MILES • 4 CYL • 4WD • MANUAL
LIGHTHOUSE81
I recently fixed my radiator hose, checked the radiator for leaks, there are no leaks, the thermostat has been changed but, i broke the wores on the sesnor switch, i also changed out the cooling fan switch, the fan wont run when the car is driving and i broke the wires on the other sensor how do i solve this problem?
Aug 25, 2009 at 11:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
well first you will need to replace the wiring that is broken. as for the cooling fan not coming on, check the cooling fan relay(s).
Aug 25, 2009 at 11:11 PM
