Is there any special reason this cylinder would be empty,when no leaks are present?
Aug 8, 2008 at 11:36 PM
✓Experienced Mechanic
Hi there,
If the master cylinder is empty, there must be a leak in the system, check the back of the master cylinder as if the slave is ok, this is where you should find your problem.
