1994 Honda Accord Hydrolic Clutch Cylinder
1994 HONDA ACCORD
180,500 MILES • 4 CYL • FWD • MANUAL
SGTMAJOR
  • 17 POSTS
Is there any special reason this cylinder would be empty,when no leaks are present?
Aug 8, 2008 at 11:36 PM
  • 31,937 POSTS
Hi there,
If the master cylinder is empty, there must be a leak in the system, check the back of the master cylinder as if the slave is ok, this is where you should find your problem.
Mark (mhpautos)
Aug 8, 2008 at 11:41 PM
