1994 Honda Accord HONDA VECI LABEL NEEDED
KATHY_OG
Electrical problem
1994 Honda Accord 4 cyl Front Wheel Drive Automatic
I CHANGED MY WATER PUMP..ALTERNATOR BELT..POWER STERRING BELT.. HAD NO PROBLEMS ..HAD TO SET TIMING USING THE JUMPER ..BUT HAD NO LABEL IS GONE FROM HOOD...APPEARED TO RUN FINE..THEN TOOK TO CAR WASH AND WASHED ENGINE...AND ALL OF A SUDDEN ITS RUNNING BAD...WONT GO FASTER THEN 15 MPH...WANTS TO STOP RUNNING...JUST DONT KNOW WHATS GOING ON..PLEASE HELP
Jan 22, 2009 at 4:04 AM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_vecif22b1_1.jpg
F22B1 Engine
https://images.2carpros.com/forum/automotive_pictures/55316_vecif22b2_1.jpg
F22B2 Engine If you can't see it, send me your email address, I'll forward it to you. Verify which engine you have. As far as your engine problem, you had the ignition system wet. Pull your distributor cap, and wipe down the rotor an the inside of the cap. Don't forget the coil as well. You may also want to pull the plug boots and make sure that you didn't get water into the spark plug chamber. This happened to a good friend of mine about a month ago. I had to go to his house with a heat gun to dry up the plug chambers...
Jan 22, 2009 at 1:53 PM
