1994 Honda Accord High PSI in low pressure valve on AC syst
1994 HONDA ACCORD
161,000 MILES • 4 CYL • FWD • MANUAL
BSPEAR12
I have an old 1994 accord and I am trying to decide whether to get the AC fixed or just let it go until the car is replaced altogether.
A week ago, (in the middle of a road trip), the AC stopped working. No gradual decrease in cooling, just completely stopped cooling.
In an attempt to identify whether this would be an expensive vs. inexpensive fix (and not able to drop $150 to find out), I used an r134 pressure guage to check the pressure in the system...now for my question:
When I put the guage on, I was expecting to find low or normal pressure, instead, the needle on the guage swung all the way around to maximum and hit the needle stop. In my mind, this eliminates the possibility of a system leak, and points to a much more expensive fix than just a recharge or hose replacement.. Your thoughts?
Braden
Aug 30, 2008 at 6:41 AM
KHLOW2008
  • 41,814 POSTS
Hi bspear12,
Was the compressor working at the time you tested the pressure?
A actual reading of the low and high pressure would assist in determining the possibvle causes. Let us know if you can get them.
Aug 30, 2008 at 7:03 PM
BSPEAR12
Regarding the compressor: when I turn on the AC, the engine RPMs take a momentary hit as the AC engages. That is the only assurance I have that the compressor is running. When I look through the sight glass on the High pressure line, I can't see anything moving. The low pressure line is not cold to the touch.
I don't have a gauge for the high pressure line, and my low pressure gauge maxes out at 80 psi. When I connect the gauge to the line (whether the AC is turned on or not) the needle goes well beyond the 80 psi mark.
Aug 31, 2008 at 2:03 AM
KHLOW2008
  • 41,814 POSTS
Hi bspear12,
From the information I can only guess that either the compressor is faulty or there is too much freon in the system.
Aug 31, 2008 at 3:03 AM
