1994 Honda Accord Engine Management Light
FOWLER31
Engine Mechanical problem
1994 Honda Accord Manual
What would cos the engine management light to come on and make the engine stall?
Apr 2, 2009 at 7:33 AM
  • 31,937 POSTS
Hi there,
The check light is an indication that the ECU has detected a fault with in the engine management system, you will need to get a scan done to identify the fault code set, this will indicate the problem with the system, start here.
Mark (mhpautos)
Apr 2, 2009 at 9:57 AM
