1994 Honda Accord door locks & cd player
CHAS0316
Electrical problem
1994 Honda Accord 4 cyl Automatic 82000 miles
When hitting the master door lock, all locks go down except for the drivers side lock forcing me to shut the door and lock it with the key or by pulling on the inside door handle and pushing the lock down. One mechanic tells me that t hi is how the locks were designed so that you couldn't lock your keys in the car. The owners manual tells me that all the locks should go down when hitting the master lock. What's up?
Also when putting in a cd, nothing happens and the cd gets ejected and after awhile the cd gets sucked back in and then ejected again. There is no error message.
Aug 7, 2008 at 11:21 AM
KHLOW2008
  • 41,812 POSTS
Hi chas0316,
The door will lock only when it is closed. When door is opened, you need to push the latch to locked position or pull the internal or external door opener to be able to lock it.
Cd player might be faulty or unable to read the disk.
Aug 9, 2008 at 4:27 AM
