1994 Honda Accord dash lights won't come on
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
SINGFORJOY
We've noticed that on occasion, the dashboard lights in the car won't come on right away, particularly if the weather is cold outside. We have a new battery and the car cranks, but it takes a while for the dash lights to come on. Can you give us an idea of what the problem could be?
Dec 21, 2008 at 2:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like it could be faulty wiring or loose wiring. In the cold, metal (wires), contract. You need to test each wire to the cluster to find out where the problem is. Chances are that the wires are barely touching, or it is exposed and touching something else and that is what is causing the issues with your dash lights.
Dec 21, 2008 at 2:21 PM
