1994 Honda Accord dash light won't work
122,000 MILES • 4 CYL • FWD • AUTOMATIC
MANNY79
My car's dash board light won't work. All warning lights are functioning. I change the instrument light for illuminating the dash board. But it still won't work, I also notice that every time the headlight was switch on. The Transmission indicator in the dashboard turns off. If the headlight was off the Transmission lndicator light works. I suspect that there is an open ground somewhere. Could you be able to point me in the right faulty components.
Jul 18, 2008 at 8:12 PM
KHLOW2008
  • 41,812 POSTS
Hi Manny79,
Check if the dash brightness control has been adjusted to minimum.
If it does not help, either the switch or the intergrated control unit (plugged into the underdash fusebox) is faulty.
Jul 19, 2008 at 7:40 AM
