1994 Honda Accord Car was stored for 4 years, and can't sta
1994 HONDA ACCORD
30,000 MILES • 4 CYL • 2WD • MANUAL
JBELLENDIR
I have had my honda accord with a swapped Honda prelude 94 engine stored for about 4 years. I left very little gas in the car and stored in the shade.
Here is what I did today:
Drained all oil, replaced oil filter.
Drained all radiator fluid and flush with fresh water.
Filled radiator with new 50/50 mix.
Attempted to siphon the gas, but nothing seemed to be there (I drove it on Empty for a while before finally storing 4 years ago). I bought 2 gallons of gasoline, and added to the tank, then siphoned a bit to see if there was any particles or gunk in it, no problem at all.
So put a new battery in and turned the key. A very strong crank but no turn over. Then I pulled out one of the spark plug cables, put a spare spark plug in it and grounded the cable. Then turned the key and checked the spark plug, no spark. So I'm thinking this is the cause for it not starting. Any ideas what I should do next?
Thanks everyone!
Jul 3, 2009 at 10:32 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi jbellendir,
Under no spark condition, you would have to :
1. Test for power supply to distributor. With ignition switch turned ON and while cranking, test Black/Yellow wire of distributor for voltage. If none then you need to check power source from ignition switch.
2. Is the Check Engine Light showing for 2 seconds when ignition switch is turned ON?
Jul 11, 2009 at 1:05 PM
