1994 Honda Accord car dosn't start changed battery stiil do
GLEN LEVY
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 175,000 MILES
175000
Tuesday, February 10th, 2009 AT 3:31 PM
F4I_GUY
  • 3,302 POSTS
Check that battery voltage is getting to the starter power wire. If there is battery voltage there, then check for power on the soleniod wire (it will be the smaller wire on the starter motor) while a friend cranks the vehicle. If there is voltage, you most likely have a bad starter. Ensure the ground cables are not corroded and that connections are still good.
Tuesday, February 10th, 2009 AT 5:57 PM
