1994 Honda Accord cant start car
PNSHER2347
1994 Honda Accord 4 cyl Front Wheel Drive Automatic 250k+ miles
been working on my accord for a week now to get it to start. i will drive it and it will die in the middle of driving. the RPM bounces around while at idle. I'm not sure what the problem is but i have replaced the spark plugs, wires, rotor, distributor cap, ignition coil, and the main relay and still no start. im going to be replacing the fuel filter tomorrow but if it still doesn't start where else should I look?
Sep 14, 2010 at 8:48 AM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter and fuel pump
Sep 14, 2010 at 9:14 AM
PNSHER2347
how do i check the fuel pressure?
Sep 14, 2010 at 9:16 AM
  • 75,988 POSTS
Get a fuel pressure tester and hook it up on the fuel rail test port, turn key on and read off the pressure
Sep 14, 2010 at 9:20 AM
PNSHER2347
well i have had the car for about a year and i have not changed the fuel filter since i got it so i figure i need to change it. this happened after i got gas could i have got bad gas? also i can hear the pump working when i turn on the car so i dont think its that but im not sure. oh also i usually run the car on almost empty if any of that info helps.
Sep 14, 2010 at 9:24 AM
  • 75,988 POSTS
Could be the fuel filter clogged or the fuel pick-up sock in the fuel tank or the fuel pump is on its way out-running the car nearly empty will cause the above
Sep 14, 2010 at 9:46 AM
PNSHER2347
hhhhmmm welll i try the fuel filter tomorrow and get back to u i hope its what it is im spending to much money on parts and still no go :(
Sep 14, 2010 at 9:49 AM
