brake lights stay on
88,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS THOMAS
My brake lights stay on.This just started yesterday.i had to pull the fuse under the hood for them to shut off.Any input on fixing it,would greatly be appreciated.
Nov 3, 2008 at 2:01 AM
KHLOW2008
  • 41,812 POSTS
Hi Chris Thomas,
There is a stopper for the brake switch located on the brake pedal which is most probably worn and dropped off. If it is missing, get it replaced, if not you need to check the pedal to switch adjustment and also for a faulty brake switch.
May 17, 2021 at 5:36 AM
CHRIS THOMAS
Thank you for replying.I did check it,and the switch is good.But their is a rubber piece on the pedal that broke off.i can not find a place that carries this rubber piece.i checked multipule places
KHLOW2008
  • 41,812 POSTS
Hi Chris Thomas,
Surprised that the part is not available. That is known as the pedal switch stopper rubber. This is a generic part that is similar to some Toyota and Nissan models.
If you were to modify or install with anything else, make sure there is sufficient free travel before the pedal starts pushing the booster push rod.
CHRIS THOMAS
I did modify it with a plastic anchor from home depot.I did find it i think at hondapartsunlimted.com
it is prewtty in expensive part.Thanks for all your input it was very helpful
