1994 Honda Accord accelerate
MISS J
  • 1994 HONDA ACCORD
1994 Honda Accord 4 cyl 114000 miles
i would like to know whats wrong w/ the acceleration on my car when I take off it goes slow. After getting to 30 its ok. When I have the ac on it goes even slower what could b the problem?
Friday, June 4th, 2010 AT 8:17 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, June 4th, 2010 AT 8:24 AM
