1994 Honda Accord 1994 Accord knocking noise
61,499 MILES • 4 CYL • FWD • AUTOMATIC
CKNIPP
I have just purchased a 1994 Honda Accord. The only thing is, it has a fairly loud knocking noise when going over bumps coming from the front. The noise seems to go away at highway speeds and is most prominent at 5-45mph. The rebound on the suspension seems fine to me. What could this noise be from? Also, the brakes are very soft but do not quite reach the floor. The car stops without making a squeel noise though when stopping from higher speeds it does vibrate a little. Thanks!
Jun 17, 2009 at 1:34 PM
SERVICE WRITER
  • 9,123 POSTS
To help the pedal height you can adjust the rear brakes out if it has drums in the back. I would check the ball joints, tie rod ends and stabilizer links for any play. The pulsation you feel is likely warped brake rotors. When you replace them, replace the pads at the same time. See our article on that.
Jun 17, 2009 at 10:45 PM
