1994 Honda Accord
1994 HONDA ACCORD
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
EASTPENA
how to replace distributor on 94 accord
Jun 27, 2010 at 10:08 AM
  • 31,937 POSTS
Hi there,
Set engine to TDC No1. remove the dist cap and number leads if you can't remember the correct order, reference the position of the rotor to the body with a dab of white marker pen, reference the position of the distributor to the head with the paint as well, unbolt dist and with draw, i think that these are an off set key drive so you can't really get it wrong, re fit and check reference marks, run and re check timing with a timing light.
mark (mhpautos)
Jun 27, 2010 at 2:13 PM
