1994 Honda Accord
BMILES
  • 1994 HONDA ACCORD
Engine Cooling problem
1994 Honda Accord 4 cyl Four Wheel Drive Automatic
My car is running hot and I need to know what to get fix my fan is working but, its not cooling off the engine
Tuesday, November 25th, 2008 AT 2:17 PM
  • 31,937 POSTS
Hi there,
Check that the thermostat is operating correctly and have the radiator cleaned & flow tested.
Mark (mhpautos)
Tuesday, November 25th, 2008 AT 3:39 PM
BMILES
We did all of that
Tuesday, November 25th, 2008 AT 3:41 PM
BRUCE HUNT
  • 3,754 POSTS
You had the level of the coolant checked and the system bled? Did you have the system pressure checked and did that turn out ok? If you have the correct amount of coolant, it is bled properly, the thermostat is functioning as it should, the system should be fine as long as there is NO blockages.
Tuesday, November 25th, 2008 AT 9:05 PM
