1993 Honda Accord What is the problem?
207,000 MILES • 4 CYL • FWD • MANUAL
DSNAX
My clutch went out on my car and I need to know if it's my slave cylinder or master cylinder or if my clutch is shot.
Feb 23, 2009 at 12:03 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0c41b4c802="dsnax"]Transmission problem
1993 Honda Accord 4 cyl Front Wheel Drive Manual 207000 miles
My clutch went out on my car and I need to know if it's my slave cylinder or master cylinder or if my clutch is shot.[/quote:0c41b4c802]
Can you start the car with it in gear, if you can and the car moves while trying to start then it is most likely either the Clutch Master or the Slave. I would recommend changing both out.
Try pumping the clutch if the clutch works after pumping then replace the Clutch Master and the Slave.
Feb 23, 2009 at 12:28 PM
