1993 Honda Accord Suspension problem?
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAMES_N_LEE
Hi
My car has noise at the front wheels when I turned.
I brought it to the car repair place and they replace both of the front axles. Noise is gone. However, when I am on freeway at 65-70 MPH with a little of bumps (normal bumps) on freeway, the car shakes a lot. I dont have this problem before replacing the axles. Can someone help me understand the problem?
Thanks
Aug 19, 2008 at 5:09 AM
KHLOW2008
  • 41,812 POSTS
Hi James,
If it is vibrations that are felt on the steering wheels, you need to get the wheels balanced.
Other than that you need to check if the CV joint repair jobs were done witj proper retightening of all parts. The steering lingkages, ball joints might have given way.
Aug 21, 2008 at 6:05 AM
