1993 Honda Accord STEERING FLUID LEAK
198,111 MILES • 4 CYL • FWD • AUTOMATIC
SEAN11981
I HAVE A 1994 HONDA ACCORD, TODAY I HAD TO BUY 3 BOTTLES OF STEERING FLUID TO TRY TO FILL THE FLUID CONTAINNER AND ALL THAT HAPPENS IS IT DRAINS OUT, ALSO IT SOUNDS LIKE ALOT OF AIR IS COMING BACK UP TO THE CONTAINNER AND ALOT OF BUBBLES AND WHITE FOAM STARTS TO FORM WHEN I START THE CAR HELP!
Apr 12, 2009 at 12:01 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5bce2828a7="sean11981"]Steering problem
1993 Honda Accord 4 cyl Front Wheel Drive Automatic 198111 miles
I HAVE A 1994 HONDA ACCORD, TODAY I HAD TO BUY 3 BOTTLES OF STEERING FLUID TO TRY TO FILL THE FLUID CONTAINNER AND ALL THAT HAPPENS IS IT DRAINS OUT, ALSO IT SOUNDS LIKE ALOT OF AIR IS COMING BACK UP TO THE CONTAINNER AND ALOT OF BUBBLES AND WHITE FOAM STARTS TO FORM WHEN I START THE CAR HELP![/quote:5bce2828a7]
If it drains out as you fill it then you may have a break in one of the line. Try looking around at the lines to get an idea of were they are and go. Then add some fluid and watch and see if you can tell were it is coming from.
Post Finding....
Apr 12, 2009 at 12:36 PM
