Hello , so my check engine light wouldnt turn off so i took it to a friend of mine that has a scanner. His scanner showed a Code #6 and said shift position switch. And i am wondering where is that located exactly? And it is also turning off when i do a sudden stop or reverse, would that be because of the shift position switch? Need help please!
Thank you
Thank you
Jul 28, 2009 at 2:35 PM
