1993 Honda Accord Reserviour tank is always getting full
252,000 MILES • 4 CYL • FWD • AUTOMATIC
PRINCEOUCH
My 1993 honda accord car radiator is always shorting water however as I continue to top the water, I noticed the one in reserviour tank is always getting filled up.
Once I had reduced the water to the level marked between min and max, but its always shoting to the top if I drive some distance to work.
please wat ould be the problem.
Dec 19, 2008 at 1:36 AM
BRUCE HUNT
  • 3,754 POSTS
Shorting water? Are you saying that the radiator gets low and the overflow reservoir gets too much?
What does the temp gauge do? Have you done a flush of the system and replaced the thermostat in the last year?
Full of questions aren't I?
Dec 19, 2008 at 3:45 AM
PRINCEOUCH
Yes Bruce,
The radiator gets low while the reserviour gets filled up each time I drive some distance like 40Km to work.
The temperature for now is ok, however at one time I started raising when am in a traffic jam but reduces once the traffic clears.
I have not done any system flush of recent.
Dec 21, 2008 at 10:41 PM
BRUCE HUNT
  • 3,754 POSTS
The cooling system's are still a pretty simple thing. They route the coolant through a couple of extra locations today but they remain simple.The system should have a pressure of around 11 lbs and the thermostat must funcition effectively for the system to work at peak performance. I would start with a look at the thermostat. I don't know if the weather is cool there right now but I would be worried once the temps of spring and summer set in.
Dec 22, 2008 at 1:55 AM
