1993 Honda Accord Replacement of water pump
DALEXANDER
Engine Mechanical problem
1993 Honda Accord 4 cyl Front Wheel Drive Automatic 153 k miles
Is it neccessary to pull the engine to replace the water pump and timming belt or can it be done another way
Mar 8, 2008 at 11:44 PM
2CARPRO JACK
  • 11,533 POSTS
That is done right there in the car. If a shop told you the engine needs to be pulled, they shouldnt be allowed to work on it......... replace both timing belts and check all the idler and tensioner bearings while in there.
Mar 9, 2008 at 1:22 AM
