1993 Honda Accord Removing Water pump
220,000 MILES • 4 CYL • 2WD • MANUAL
CAT95204
Trying to remove the water pump on my 93 Honda Accord and am having trouble removing the crank bolt.
Is it a reverse thread? Is there a special tool I need to get it off.? It just won't turn.
Jul 4, 2008 at 1:09 PM
KHLOW2008
  • 41,812 POSTS
Hi cat95204,
The bolt is torqued at 150 ft/lbs, normal thread.
Either you have a high torque impact wrench or you need a special tool to hold the pulley.
Make sure you get the timing belts markings correct before removing them. The balancer shaft belt can cause a lot of problem if not correctly installed.
Jul 5, 2008 at 12:59 AM
