1993 Honda Accord oil pressure light
277,000 MILES • 4 CYL • 2WD • AUTOMATIC
SNIPER1228
I was driving to work about 11 miles freeway..oil light came on and noticed dipstick was dry...added 4 quarts of oil. Light went off. Later, at home, I noticed a large oil spot in the driveway. Could the oil sending unit be bad and if so how do i repair it?
Aug 24, 2009 at 9:20 AM
  • 75,988 POSTS
Check the oil pan and drain plug-low oil will cause the oil light to come on. Level okay check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Aug 24, 2009 at 9:37 AM
