You may or may not have low oil pressure. This NEEDs to get looked at. IF you have a gauge that you can check the oil pressure with, hook it up to where the oil sending unit is. At idle the pressure should be 10 pounds, at 3000 rpm is should be 50 pounds. May have a bad pump, clogged pump or other.
SPONSORED LINKS
Saturday, May 19th, 2007 AT 7:41 PM
