1993 Honda Accord Head?
1993 HONDA ACCORD
18,400 MILES • 4 CYL • FWD • MANUAL
BTOONED
the car broke a timing belt. replaced it runs great for about 10 minutes til it warms up. Then it blows the #2 plug wire off. just the wire. You can feel compression out the vale cover.Valve seal, cracked head? the idle also surges up and down.map sensor?
Sep 5, 2010 at 3:53 AM
KHLOW2008
  • 41,814 POSTS
Hi btooned,
Check if the spark plug is correctly torqued.
Surging is mostly due to vacumn leaks, low coolant level, faulty FITV and or IAC.
Sep 5, 2010 at 4:46 AM
