FUEL FILTER?
KIMC123
i have a 1993 honda accord 10th anniversary and i want to know where the fuel filter is located.
Jan 7, 2009 at 12:31 AM
ZACKMAN
  • 4,202 POSTS
Hello this guide can help us with diagrams below to help you on your car. https://www.2carpros.com/articles/how-to-change-a-fuel-filter
https://images.2carpros.com/forum/automotive_pictures/55316_93accord_1.jpg
Jan 7, 2009 at 5:17 PM
SPEEDNEED15401
where is fuel filter on 89 honda accord lx
Sep 19, 2020 at 6:30 AM (Merged)
  • 75,988 POSTS
The fuel filter is up in the engine compartment. Here is a guide and a diagram below to help you get the job done.
Cheers
SAVID
where is the primary fuel filter? thank-you
IMPALASS
  • 3,112 POSTS
Hello - I have attached a pic where the filters are.
https://images.2carpros.com/forum/automotive_pictures/248015_Fuel_Filter_2.jpg
BCLOPERS
Engine Performance problem
1987 Honda Accord V12 Manual 184000 miles
the car has been setting for quite a while,started every now and then.when started up awhile back it would not idle,it would die. changed the fuel filter and it ran good.then sat for a short time ran the car for about 1 hour and it idled fine. then it started not to hold an idle again,and thats where were at now.
Please help
Bruce
KHLOW2008
  • 41,812 POSTS
Hi Bruce,
Thank you for the donation.
What engine do you have and is it carburetted or fuel injected?
Honda does not have any V12 that I know of.
BCLOPERS
carburetted,
4cylinder
KHLOW2008
  • 41,812 POSTS
For carburetted models, the most common cause for the engine to stall during would be the fuel cut solenoid. It is located at rear center of carburettor. Remove the solenoid and with ignition ON, ground and if it clicks, it is good. If not, check for battery voltage at the wire. If voltae is avaiable, the solenoid is bad.
Use compressed air to blow into the port for installing the solenoid, reinstall and retest.
SLEEPYNOEL
i have a 96' Accord with 113k. I asked a guy to change my fuel filter and he told be that he recommends that I also change my fuel pump at the same time. I he said that it is very probable that the fuel pump will stop working once I change the fuel filter. This is the first time that I ever heat something like this. He mentioned that with Accord that usual happens if the pump is not changed with the filter. Can you time me if this is a true statement or if he is looking to get more money out of me?
  • 31,937 POSTS
Hi there,
I have change a few of these filters and never had a pump fail soon after, come to think of it i don't think i have ever replaced one of these fuel pumps, You always replace the filter if a new pump is fitted, but in this case, i think it is a bit extravagant to say the least.
Mark (mhpautos)
STEVIEH
1997 Honda Accord Special Edition, 153000 miles. I need to ask two questions, please. Where is the fuel filter on this car? Also, replacing the valve cover gasket, spark plugs and wires, there are 4 o-rings in the gasket kit. Where do these o-rings go? Thanks for your help.
Sep 19, 2020 at 6:31 AM (Merged)
BRUCE HUNT
  • 3,754 POSTS
The fuel filter should be on the firewall. Follow the fuel lines coming off the injector rail.
The orings are they big or small. Sometimes people call a washer an oring. You might be talking about the washers that go on top of the plug wire wells or you could be talking about the orings on the injectors.
CODY-ODY
  • 57 POSTS
the fuel filter on that model is either under the vehicle near the subframe just below the driver's floor(on the incline and a little tough to see sometimes) the other place is (can't remember exactly what year they started doing this) in the fuel tank which you only service IF you have a fuel pressure problem(basically its just a screen on the end of the pump)
The answer to your other question is If the o-rings are fairly thick the they go in the valve cover to stop oil from entering the spark plug holes .If they are real skinny then they go underneath the rocker arm assembly(also to prevent oil from entering the spark plug holes but at a lower level)
