1993 Honda Accord elevation problem
143,000 MILES • 4 CYL • 2WD • AUTOMATIC
THISGUY80
i have a car and when ever the car is elevated it turns off. it seems that it only happens when the car is elevated from one side. for exsample right before i pull up to a driveway when im between the street and the sidewalk the car gets elevated from the front and it turns off but i have like a 1/4 of gas should it do that. ive had cars almost on empty before and they have never done this before?
Sep 11, 2009 at 9:11 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model a DX, EX, LX or SE and what is the engine size in liter.
Sep 11, 2009 at 9:22 AM
THISGUY80
dude im not sure but i think its a lx does it really matter. i do know its a 2.2 litter the thing is that i just bought the car.
Sep 11, 2009 at 10:03 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info…………as for the model….yes in some cases it does matter. Our manuals are set up by model…specific model….many times when we are looking up info we even need to know the 5 or 8th digit of the VIN. Many times the TSBs are specific to certain models and at times we may even ask the full VIN or the month/year manufacture as some items only apply to certain numbers off of the assembly line.
So…..long story short….it helps us, and you, be more specific to just your vehicle so we aren’t running bad rabbits…..plus….it helps you know your vehicle better. We have also started chasing a problem and ask the customer a few questions and they realize they are off a year or so….or have given us other info about the car that is incorrect. So since we can’t see the car you become our eyes, ears etc and we work through it together. Hope that helps.
My guess would be your fuel gauge or sending unit may be wack……..
Here is a couple of tests you can do to check it out. If you have never messed with
READ THE CAUTION
TESTING
FUEL GAUGE TEST
CAUTION: Turn ignition off before fuel gauge pointer reaches "F" mark. Failure to turn ignition off before pointer reaches "F" mark may damage fuel gauge.
1. Ensure ignition switch is in OFF position. Check fuse No. 1 (10-amp) in dash fuse box. Remove fuel gauge sending unit access cover in luggage compartment. Disconnect 3-pin connector from sending unit.
2. Connect voltmeter positive lead to Yellow/White wire and negative lead to Black wire. Turn ignition on. Voltage should be 5-8 volts. If voltage is incorrect, check for open circuit in Yellow, Yellow/White and Black wires. Check for poor ground connection.
3. Turn ignition off. Install jumper wire between Yellow/White wire and Black wire. Turn ignition on. Ensure fuel gauge pointer starts to move toward "F" mark on gauge. If fuel gauge pointer does not move, replace fuel gauge. If fuel gauge is okay, check fuel gauge sending unit.
FUEL GAUGE SENDING UNIT TEST
1. Ensure ignition switch is in OFF position. Remove fuel gauge sending unit access cover in luggage compartment. Disconnect connector from fuel gauge sending unit.
2. Remove fuel gauge sending unit. Use an ohmmeter to measure resistance between fuel gauge sending unit terminals with sending unit float held at empty (down), half-full (middle) and full (up) positions. Compare readings with FUEL GAUGE SENDING UNIT RESISTANCE table. If resistance values are incorrect, replace fuel gauge sending unit.
Float Position Ohms
Empty 105-109
Half-Full 27.5-37.5
Full 2-5
Sep 11, 2009 at 3:33 PM
IMPALASS
  • 3,112 POSTS
Hello - Hey while I have you I forgot to tell you..... Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recall_27.jpg
Sep 11, 2009 at 3:36 PM
THISGUY80
a thanks man i appreciate ur help im gonna try ur edvice but know that i have u on u mind awnsering a quick question when i back up "reverse" the car shakes a lot it doesent turn off or nothing and it only does it when i reverse a friend of mine told me i could be the transmission mount what do u think?
Sep 11, 2009 at 4:50 PM
IMPALASS
  • 3,112 POSTS
Hello –
I would check all of the mounts………have the hood up and watch the engine and go from park to reverse and see how much it moves, then reverse to drive – watch then back….definitely check all the mounts.
Also do you have disk or drum brakes on the rear
Sep 11, 2009 at 5:24 PM
