1993 Honda Accord d4 light flashing
197,563 MILES • 4 CYL • 2WD • AUTOMATIC
ROOBOK22
OKay my d4 light is flashing i took it to this shop and they told me it was an engine code 4 and a tramission code 10... what does those 2 codes mean..
Feb 19, 2010 at 12:02 AM
KHLOW2008
  • 41,812 POSTS
Hi roobok22,
Engine
Code 4 = Crankshaft Position Sensor ( CKP )
Sensor is located inside distributor.
Could the trouble code retrieval be incorrect? I believe it could be Code 6 = ECT sensor which is equivalent to the Code 10 for the trnasmission.
Transmission
Code 10 = Engine Coolant Temperature sensor.
Check the ECT sensor wire connections ( 2 wire ) for looseness and contaminations under the distributor, on the head next to the Temperature Sending unit ( single wire).
Feb 22, 2010 at 7:28 AM
