1993 Honda Accord CHANGING BRAKE PADS AND ROTORS.
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAZER2118
HOW DO I REMOVE WHEEL BEARING FROM THE FRONT HUBS? THE BOLTS ARE NOT BOLTS BUT HAS A GEAR TYPE HEAD ON IT ? THE MM DOES NOT FIT. IS IT A SPECIAL TYPE OF BOLT HEAD??HONDA SAYS IT SHOULD BE A NORMAL BOLT.THE ALLDATA SAYS THERE SHOULD BE NO PROBLEMS.PLEASE HELP!
Apr 27, 2010 at 4:34 AM
KHLOW2008
  • 41,812 POSTS
Hi razer2118,
There are 3 types of bolts used.
1. 10 mm hex.
2. 10 mm 12 point.
3. torx bit head. ( can't remember the size.)
Yours should be the torx bit type.
May 1, 2010 at 4:36 AM
