HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine Cooling
Water Pump
1993 Honda Accord car building pressure
JOEYSABRINA09
MEMBER
1993 HONDA ACCORD
4 CYL
2WD
AUTOMATIC
200 MILES
New water pump new headgasket head has been to machine shop new radiator, thermostat.
Sunday, September 13th, 2009 AT 4:35 PM
IMPALASS
MECHANIC
Hello -
To better assist you is your model the DX, EX, LX, or SE and what is the engine size in liter?
Also, I am not sure of your question - what is it you are wanting to know
SPONSORED LINKS
Sunday, September 13th, 2009 AT 4:50 PM
Please
login
or
register
to post a reply.
Related Water Pump Content
1991 Honda Accord Watert Pump
The Watert Pump Is Ready For A Cemetary. My Husband Is A Mechanic And Got Nuts/bolts Off To Get To The Water Pump. The Last Thing That He...
Asked by
suegeo74
1991
HONDA ACCORD
GUIDE
Water Pump Symptoms
The water pump is designed with a weep hole to allow coolant to leak from its housing before it can reach the shaft bearing which will cause the shaft to lock up and stop...
Coolant Leak 1993 Accord
My Engine Has A Coolant Leak Coming From The Backside Of The Lower Timing Belt Cover-just To The Inside Of The Cover On The Engine. There...
Asked by
bohn
1993
HONDA ACCORD
1993 Honda Accord Coolant Leak/heat Gauge Flucuating
Back In October 09 Water Pump Went Out And Engine Overheated. Got Water Pump Fixed, But When First Start Up Afterwards Seems To Be A...
Asked by
teddyjoe
1 ANSWER
1993
HONDA ACCORD
Coolant Leak Fluid Keeps Disappearing, And I Know I...
My Honda Accord Wagon Was Recently Involved In A Minor Fender Bender. Its Hoods Bent, And The Drivers Side Headlight Assembly Shot, But I...
Asked by
laxman0131
1993
HONDA ACCORD
1993 Honda Accord Reserviour Tank Is Always Getting...
My 1993 Honda Accord Car Radiator Is Always Shorting Water However As I Continue To Top The Water, I Noticed The One In Reserviour Tank Is...
Asked by
princeouch
1993
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Water Pump
Water Pump Replacement
Coolant Leak Repair
Online car repair manuals
