1993 Honda Accord Brake problems
198,374 MILES • 4 CYL • FWD • AUTOMATIC
REGINATAYLOR
We have changed the brake pads on all 4 wheels replaced the brake fluid and bleed the brakes but the car still won't stop without pumping the brakes. What elese should we check?
Sep 22, 2008 at 1:58 AM
KHLOW2008
  • 41,812 POSTS
Hi reginataylor,
If the brake pedal sinks when you keep it depressed at a stop, the master cylinder is faulty.
If the pedal is very heavy, the power booster is faulty or vacumn is leaking.
Sep 30, 2008 at 6:08 AM
