1993 Honda Accord Brake lights, shift release not working.
315,000 MILES • 4 CYL • FWD • AUTOMATIC
ALEKI
My shift release stopped working and soon after realized my brake lights aren't working either. Figuring they were related I replaced the brake switch thinking it would solve both problems but it did not fix it. Now I have no idea how to diagnose this issue.
Thanks in advance!
Jun 27, 2010 at 6:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
when brake lights fail it will also cause shift to fail. check fuse #25 (20 amp) as well as wiring to the switch.
Jun 27, 2010 at 7:18 AM
ALEKI
[quote:e39a21556a="bluelightnin6"]when brake lights fail it will also cause shift to fail. check fuse #25 (20 amp) as well as wiring to the switch.[/quote:e39a21556a]
Oh my goodness, thank you a thousand times over. I thought I was going to end up tracing every wire, and it was just a stupid fuse. Let's hope O'Riley will let me return the switch.
Jun 27, 2010 at 7:38 AM
