1993 Honda Accord a/c made gurgling noise then stopped...
165,000 MILES • 4 CYL • FWD • AUTOMATIC
MEINSHEIZER
i have a 93 honda accord. here is my problem. my heater hose burst and then over heated. took it to autozone and replaced the hose on the spot and refilled the radiator. then a couple of days later when the a/c was on we would hear a gurgling noise that would go for a couple of seconds and then stop and go then stop. continued for a week or so and then the a/c stopped blowing cold. the compressor still kicks on when you turn on the a/c in the car just no cold air. i have not checked the pressure in the a/c system yet. have not checked any fuses or relays. would the heater hose have caused this problem? and if so then how?
Oct 15, 2008 at 8:34 PM
KHLOW2008
  • 41,812 POSTS
Hi meinsheizer,
Not likely for the heater hose to be the cause.
I would suggest testing the pressure first. There might be a leakage in the system and you don't have enough freon in system now.
Oct 21, 2008 at 6:31 AM
