I was wondering if there were any tests that I could perform on the ABS FUSE box to tell if that is the reason for the ABS light comming on other than the normal fuse continuity test? I am also having some intermittent brake pedal loss of pressure. I only loose pressure when stopped for a lengthy time. Coulld the two be related. My HAYNES manual refers me to a professional. Thank you for this forum. I learned of the website from searching for shift solenoids for the same year and make and was very insightfull
Feb 17, 2009 at 11:36 AM
