1993 Honda Accord Abs light on the dash
69,110 MILES • 4 CYL • 2WD • AUTOMATIC
KEWLKATT
I was wondering if there were any tests that I could perform on the ABS FUSE box to tell if that is the reason for the ABS light comming on other than the normal fuse continuity test? I am also having some intermittent brake pedal loss of pressure. I only loose pressure when stopped for a lengthy time. Coulld the two be related. My HAYNES manual refers me to a professional. Thank you for this forum. I learned of the website from searching for shift solenoids for the same year and make and was very insightfull
Feb 17, 2009 at 11:36 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
The ECU has detected a fault in the ABS system, and there will be a logged fault code, get a scan and this should give you the faulty component , normally its a wheel speed sensor issue, as for the pedal pressure, this may be a master cylinder by-passing internally, if the pedal falls away under prolonged light pressure this is often the problem, harder pressure expands the seals and pressure is maintained. have this inspected first.
mark (mhpautos)
Feb 17, 2009 at 8:09 PM
