My clutch went the other day meaning i put it to the floor and wouldn't go into any gear is was snapping to the floor and sticking down, so i was looking at the master clutch cylinder seeing it was leaking down the inside firewall so i figured this the problem and replaced it today. Got the new unit back in still snaps to the floor and when i pumped the clutch by hand to bleed it i get no pressure and i got no fluid to the bleeder on the slave cylinder. So i cracked open the inlet pipe on the Slave cylinder and i get fluid there when i pump so i close that back up and try again at the bleeder and i get nothing still does this mean the slave cylinder is bad or is there another problem. Thank you for the help
Aug 9, 2010 at 2:30 PM
