1993 Honda Accord
SWARTHOS
Engine Mechanical problem
1993 Honda Accord 4 cyl Two Wheel Drive Manual
we have replaced the fuel pump three months a go and we have just replaced the ignition coil, the cap, the spark plugs, and the main relay and the car still will not start
Sep 12, 2010 at 10:35 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Sep 12, 2010 at 10:53 AM
