1993 Honda Accord
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
R. ZANOTTI
I replaced the brake master cyl, but
the brake pedal, when you start the ca,r is still spongy.
When the car is not running,the brake is at the usual hard to push down.
What is the sequence to bleed the system or do
I have another problem within the brake system
It is a 10 th Adv with ABS Brakes.
I appreciate your time and effort in this matter.
Bob
Apr 8, 2010 at 6:39 AM
KHLOW2008
  • 41,812 POSTS
Hi Bob,
Bleeding sequence are :
LR, RF, RR, LF.
Ensure the brake caliper slider bolts are not stuck and moves freely. Remove the brake pads and reinstall to caliper test slider bolt movements.
Check the brake pads for signs of uneven wear, different thickness on same pad. They are indications of seized slider bolts.
Apr 11, 2010 at 12:12 AM
