1993 Honda Accord
1993 HONDA ACCORD
HONDA35
  • 5 POSTS
Drive Train Axles Bearings problem
1993 Honda Accord 4 cyl Four Wheel Drive Automatic 252,?? miles
How do you change front wheel bearings?
Oct 13, 2008 at 12:29 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Hi Honda35
You need to remove the brake caliper with mounts.
Remove the rotor.
Remove the CV joint centre nut.
Use slide hammer to take the hub out
Remove the rotor, 4 pcs of bolts.
Press the bearing cone out.
Remove lower arm ball joint.
Remove the CV joint.
Remove the 4 holding bolts and take out bearing.
Installation is by pressing in the hub and then install rotor before installing assy to knuckle.
Oct 20, 2008 at 11:47 AM
