1992 Honda Accord turns off while driving
160,000 MILES • 4 CYL • FWD • AUTOMATIC
DASODI77
distributor cap has been checked,spark plugs are new,ignition coil is good.still no good.i was told there is a "coil" under the steering column that might heat up that may cause it to heat up and shut the car down
Feb 20, 2010 at 3:38 AM
KHLOW2008
  • 41,812 POSTS
Hi dasodi77,
When engine stalled, were the dash indicator lights showing?
Was it easy to restart?
Under dash is the PGM-FI main relay. The other possible cause would be the ignition switch.
Feb 28, 2010 at 3:00 AM
