1992 Honda Accord Transmission
197,000 MILES • 4 CYL • FWD • AUTOMATIC
GOODDOG
When the car is warm the gears do not engage. I checked the fluid and it is fine.If I shut the engine off and let it sit for a second then start it again it will engage for a very short time.Also the engine seems to have a high pitch whirling sound when in neutral and I rev it a little.
Nov 7, 2008 at 6:17 AM
  • 31,937 POSTS
HI there,
Due to the highly complex nature of automatic transmissions, you must run a number of physical tests to determine most faults, in your case i feel that there may be an internal oil leak in the high pressure side of the transmission, i suggest that you get it inspected and a report made on it condition.
Mark (mhpautos)
Nov 7, 2008 at 8:02 PM
