1992 Honda Accord timing mark on flyeheel
12,000 MILES • 4 CYL • FWD • AUTOMATIC
L_WILDEBOER
is the red mark on the flywheel the timimg mark? There is also a nob with a notch located in another position on the flywheel. Which is the correct one?
Jan 18, 2009 at 3:09 AM
KHLOW2008
  • 41,812 POSTS
Hi l_wildeboer,
The red mark is the ignition timing mark. It is flanked by 2 marks, each 2 degrees apart for plus/minus the recommended timing. Another white mark with a "T" further up would be the crankshaft TDC mark.
Jan 11, 2021 at 3:12 AM
